Re: gfci location on hydromassgae bath tub
Have you ever wondered why faceless gfci's come with plastic cover plate screws? At least the leivington does. I was just reading the paper work that came with it and they are listed for in the tub area mounting and are switch rated I was shocked!(no pun intended)
so this is what 680.22 allows
680.22 Area Lighting, Receptacles, and Equipment.
C) Switching Devices. Switching devices shall be located at least 1.5 m (5 ft) horizontally from the inside walls of a pool unless separated from the pool by a solid fence, wall, or other permanent barrier.
Alternatively, a switch that is listed as being acceptable for use within 1.5 m (5 ft) shall be permitted.
huntinmo1 the def. in 680.5 clearly allows for breakers but it could be a local requirment and they could be combinding 680.41 with 680.43(A)(3) as was said. But 680.41 doesn't apply to dwellings as it sezs
680.5 Ground-Fault Circuit Interrupters.
Ground-fault circuit interrupters (GFCIs) shall be self-contained units,
circuit-breaker or receptacle types, or other listed types.
680.41 Emergency Switch for Spas and Hot Tubs.
A clearly labeled emergency shutoff or control switch for the purpose of stopping the motor(s) that provide power to the recirculation system and jet system shall be installed at a point readily accessible to the users and not less than 1.5 m (5 ft) away, adjacent to, and within sight of the spa or hot tub.
This requirement shall not apply to single-family dwellings.
[ March 11, 2003, 09:35 PM: Message edited by: hurk27 ]
