wireday
- New England
- Master electrician
The 2020 Code cycle made significant changes to this section, such as: All 125- through 250-volt rated receptacles supplied by a single-phase branch circuit rated 150 volts or less to ground are required to have GFCI protection. So is this confusing? If I am working in a commercial building installing receptacles for 5 offices,no water in sight, does it need GFCI? Does NEC mention anywhere it pertains just wet/damp locations,
