pcarcich
- Fayetteville, Georgia
I am an engineer with a Fortune 500 company. Several years ago an operator in one of our plants reported a "tingle" adjusting a piece of equipment that was ungrounded & resistance heated using a 480 VAC 3 phase delta circuit. We immediately grounded the equipment & checked the NEC code. The electrical engineer in the plant checked the NEC code & found that GFCI is required for 480 VAC resistance heating applications. All of the 480 VAC resistance heat panels were replaced ASAP with new panels with GFCI plus all of the 480 VAC resistance heating equipment is now grounded. We are now buying a new piece of equipment for another project that is resistance heated with 240 VAC but the supplier does not include GFCI in the design because a "given amount of known leakage" in the spirally wound heated hoses would cause nuisance trips. My questions is: Does the NEC code require GFCI protection for this application or is proper grounding sufficient?
