gary
- California
- Retired electrical contractor / general contractor
I have a customer who wants me to put rope lights on an outdoor trellis 10' above an in-ground spa. Power is to come from the master bedroom plug circuit which is on an AFCI breaker. I mounted an FS box with a receptacle & bubble cover up on the trellis and plugged in the rope light. I planned to use a combination GFCI / switch in another FS box mounted on a support column to control the lights, but now owner says he wants the lights on a dimmer. :shock: If I used a dimmer to feed the lights through a GFCI receptacle, would the GFCI provide any shock protection when operating at less than 120 volts? :shock:
