md40022
- Chicago, Illinois, United States
Hello, new member here. Hoping someone can shed some light on an ongoing headache we've been dealing with.....
We manufacture vending machines and are based out of the Chicago area. We have a customer down in Florida who is having an ongoing problem, so all of our testing and troubleshooting has been down with this customer over the phone. Therefore, I hope all of the info the customer has provided me with is accurate, but here it goes....
The vending machine has an in-line 15amp GFCI on the power cord. Ever since the customer has owned this machine (about 1-2 months now) the GFCI will trip out within an hour or so of the machine being powered on. The machine is just in normal standby mode meaning no motors or anything are running which would cause a higher amp draw. This is a non-refrigerated machine, so there is no high amp draw of a compressor in play here either.
First troubleshooting we did is had the customer run an extension cord and plug the machine into a different outlet on a different circuit breaker. Same issue, within an hour of being powered on the GFCI trips.
We then sent a new power cord with in-line GFCI to the customer. Again, same issue remains.
I then had the customer remove all of the outputs off of the power supply. Meaning the machine's control board, motors, LED lighting, etc. were all removed from the load. At this point it was just a power cord plugged into a power supply, with nothing else on the load.... Same issue, GFCI trips out.
At this point, seeing that a brand new GFCI was tripping out with only the power supply on the load, we sent out a brand new power supply..... Still, same issue.
At this point, the customer put one of the cheap $7 outlet testers on the outlet and there seemed to be an intermittent ground short being detected. When he first connected it, all read good. But as I was on the phone with him, about 10 minutes into the conversation a ground short showed...... So the customer then had his electrician out to the site and he ran a brand new dedicated line for the machine. But even with a brand new dedicated line, we have the exact same issue.
I then sent yet another GFCI power cord to the customer. This used a different make / model GFCI..... Yet we still have the same issue!
Just for the sake of testing, I finally asked the customer to take one of the power cords w/ in-line GFCI and one of the power supplies to his home and to plug it in at his home..... He did this and said the GFCI does NOT trip out in his home.
The location of the vending machine is a laundromat.
At this point, I am at a loss. It almost feels like the customer is not being honest with what he is telling me when we troubleshoot, because we have been through 3 GFCI power cords and 2 power supplies and still have the same issue. And this is with a new dedicated line being run for the machine.... I can't imagine anything inside of the vending machine itself is causing the GFCI to trip as we have completely isolated the GFCI and Power Supply so the rest of the machine should be completely irrelevant at that point.
Is there anything I could be overlooking here? I hate the fact that I am not local to this customer, because of course that has me wondering if I am getting inaccurate info from him. Any thoughts? The fact that a power cord / power supply run fun without tripping the GFCI at this person's home, yet those same items trip out at the laundromat location has me thinking this could be related to the electric panel at the laundromat, but would running that new dedicated line not have resolved that? Any feedback at all would be appreciated because I am at a complete loss.
