We generally install cans, whether line voltage (Halo H7, with shower trim) or low voltage (can't remember specs, but uses mr16 lamp) in shower/tub areas. My boss wants them GFCI protected. We usually do that by running the lighting circuit power through a general use receptacle located on a convenient wall in the bathroom (not connected to the 20A required receptacle circuit located at vanity) then up to the shower light switch. That way if it trips they can be reset without a trip in your bathrobe to the mechanical room.
I thought it was just something he wanted in an effort to go 'above and beyond', but then I've heard him recently make comments about it being required by code. I can't find any code that requires this. The only thing I see that would require GFCI protection is if the manufacturer requires GFCI protection. 410.4D tells you what types of lighting fixtures you can't put in a shower or tub area, and that the fixture that you put in this area has to be listed for wet locations if subject to shower spray. I can't find anything that talks about "GFCI protection for all shower lights".
As long as we install cans with trim listed for use (shower trim) I don't see where they have to be GFCI protected. The only thing I can see that would require GFCI protection is if the Manufacturer requires it (which doesn't apply to what we generally install, I think).
If anyone has feedback about some code that I might be missing I'd like to hear it. I'm not looking for proof that my boss is wrong, I just need to understand if I'm missing something here. Someday I might have this question on my j-man's test.
Thanks,
Sky
Thanks,
Sky
