goldstar
- New Jersey
- Electrical Contractor
I'm currently working on a job where the sump pump in a residential basement either failed and burnt out (it was either clogged or failed to shut off) Because I needed to get into that basement to do some wiring I first had to buy a utility pump and a hose and pump the sitting water out. That took 6 hours to evacuate 12" of sitting water. Then I purchased a new sump pump and the manufacturer's recommendations state that it should be plugged into a GFCI receptacle.
Now, writing that into the pump instructions just to CYA I think is a travesty. IMHO, I would rather let the pump burn out than have it fail due to a GFCI problem. What hazard could possibly exist if it does develop a GFCI problem ? It's in a sump pit. By the same token, installing a GFCI for a sewer ejector pump is beyond a travesty. When the crap backs up in the basement, people will be changing out the GFCI protection.
I'm not expecting many responses. This is just a rant :-(
