This is a slab on grade green house. The lights you see in the picture are plugged into duplex receptacles which I guess also doubles as a means of disconnect. The circuit breakers are not GFCI breakers.
When I go tell the green house manager that the circuit I'm installing for a new fan will be GFCI protected he's probably going to complain.
Am I missing something here? Can I install a non GFCI duplex outlet here?
Thank you all in advance.
Sent from my Pixel 2 using Tapatalk
