BMacky
- Foster City, CA
I have installed some low-voltage light fixtures in a shower. They are step lights, vertically mounted, and the fixtures are wet-location rated. They flush mount to the finished surface (slate) and the transformers are remotely located. The primary side of the transformers are on the load side of the bath GFCI.
My question is does the transformer in any way isolate the monitoring circuitry of the GFCI from possible ground faults in the fixture on the low-voltage side?
Thank you.
Thank you.
