DChambers772
- Western North Carolina
- Electrician's Apprentice
Good afternoon,
Hopefully I'm not violating any rules by posting. I read the pinned thread and I do not think it does. I also searched the forum and didn't find anything that really explained what I was seeing. I am currently working as electrician's apprentice since about May of 2022, so my experience is limited in the number of things I just simply haven't seen or just don't know what to look for yet.
I was hoping someone here might be able to shed a little light on something I came across this afternoon.
I was sent to take a look at a GFCI outlet at a car wash. There were two of them. I found the GFCI upstream which was obviously fried, and the insulation on the wires were blackened from the receptacle to where it met the conduit entering the box. I had been instructed just to clean the wires up as best I could and swap the GFCI out with a new one. Went ahead and did just that, double checked to make sure the line and load sides were correct, and then went ahead and wrapped it once over in electrical tape and went to put it back in.
The plug tester read correct, but as I screwed it down it would switch from reading correct to Hot/Ground reversed. I took it back out, double checked to make sure this was not the case. Went ahead and wrapped the hot wires with electrical tape where damaged just to make sure they weren't making contact with any other conductors, cut the screws down in length thinking maybe somehow, they were making contact with something inside of the box, and tested it again. Everything read correct. Went to screw it back down and the same thing happened. I could see it on the plug tester switch from correct to hot/ground reversed as I screwed it down.
I had been in contact with my boss the whole time and was eventually told to just leave it. He'd take care of it. I put it and the GFCI downstream back together and just decided to test them again to check. The top outlet on the first GFCI read correct. The bottom outlet and the downstream GFCI still read Hot/Ground reversed. I double checked my plug tester on another receptacle, and it was working correctly.
I was hoping someone could explain to me what might cause this, or if I had done something wrong in reinstalling it. I've been searching the internet and the only thing I could come up with was that maybe the neutral wire on the load side is just damaged to the point it is giving the plug tester a false reading there and downstream from it.
