pkelectrical
- NJ
Residential bayfront home. House sits on pilings-grade level. 2 floors of living space.
Hydraulic elevator with machine room located on 1st floor. There is no pit.
I had final inspection and failed for "GFCI receptacle missing on top of the elevator".
1. I have provided all the circuits to the elevator machine room. I installed a light and smoke detector in the elevator shaft on the ceiling.
2. Elevator contractor installed disconnects and all the wiring for the elevator using the circuits I provided.
Is there a code that requires a GFCI receptacle on top of the elevator in NEC? I could not find it in the code book.
ASME A17.1 - 2.14.7.1.4 Requires lighting and receptacle on top of the elevator. The exception says that light is not required on top of the elevator in residential elevators. That means GFCI receptacle is still required.
Can the inspector hold me to those requirements if the NEC does not require it? and elevator wiring was done by another contractor (elevator contractor)?
Not sure how to even go about installing GFCI receptacle on top of elevator.
