wirenut1980
- Plainfield, IN
I have been told that if there is a gfci receptacle on a branch circuit in let's say a residence, and there are other non-gfci receptacles on that same branch circuit, and all the grounding conductors are tied together, then the non-gfci receptacles are protected by the gfci receptacle. How is this possible? I thought that the gfci only compared the current between the hot and neutral wires on the load side of the receptacle only. Essentially it detects leakage to ground, but if this is all on the load side of the receptacle, how does it protect the other receptacles?
