B
bthielen
Guest
A few years ago I had remodeled my bathroom. As part of my lighting circuit, I included a ceiling exhaust fan to remove excess humidity. When it was inspected I learned that our inspector required the lighting circuit, in particular the exhaust fan, to be GFCI protected. He indicated that it had to do with its proximity to the bathtub/shower. Now, I have a neighbor that is remodeling his bathroom and during conversation I mentioned that he may need to install GFCI protection for his exhaust fan. I have access to the code book so I told him I would look up the requirements. I have not been able to locate the code that specifies this requirement. Can anyone direct me to the appropriate code?
So far I have referenced 410.4 describing what may be space limitations. Incidentally, can someone define what a ?Paddle? fan is? Never heard this term used before. I have also referenced 680.43 (B) and 680.71, but am not sure how these may apply. I reviewed 210.8 (A) but this refers to receptacles. Does a lighting fixture outlet fall within the description of a receptacle and therefore, all bathroom lighting fixtures also require GFCI protection? This doesn?t seem to hold true since lighting outlets in kitchens, garages, etc. don?t seem to require it.
Thank you,
Bob
Thank you,
Bob
