GFCI Requirements in Industrial applications
TrentR
New member
Ohio
Can anyone clarify from a code requirement the need to install ground fault circuit breakers in an industrial control panel for a welding application? I understand a clear requirement from NFPA 79 that requires ground-fault-circuit-interrupter (GFCI) receptacles for any control panel utility outlets. Is there any reference to other breakers in the control panel?
