wireman1
In a new manufacturing plant the contractor has mounted duplex receptables on the steel columns ,forconvience outlets for extenshion cords etc for use in the plant. the receptables are not gfci ptoteced extenshion cords get damaged ,grounding pins get broken off plugs greacting a dangerous situation for plant personel. atricle 210 8 b does not address manufacturing plants ,yet they are required in kitchen areas of resturants .can the inspector use 9o - 4 to require gfci ptotection for the outlets ?If not this looks like a good proposal for a code change .
