- Tennessee NEC:2017
- Semi-Retired Electrician
I just wired a set of storage buildings. These are similar to what people rent for storage but they are for RVs and boats. Seems there is a demand for these as I had no idea they even existed. I've seen them for boats but not RVs.
This building has 11 units, each is 50' x 14'. Each unit has (1) receptacle, (1) light, and (1) timer switch for the lights.
I had my rough inspection today and everything passed except the inspector said I had to change the already installed duplex receptacles to GFCI before he would pass the final.
I searched the code before I started and didn't find anywhere that showed GFCI was required for this type building being it is a non dwelling. I questioned the inspector and he said 547.5(G) was his reference. I said that section is for Agriculture not storage rentals. Then he said our State had an amendment for this type building. I have the State amendments and don't see it.
Is there anything in the NEC that would require GFCI for these type buildings that I (or the inspector has the wrong code section) have missed?
