K8MHZ
- Electrician
Scenario:
Old two wire in workshop with concrete floor.
Mission:
Replace old two wire receptacle with new GFCI. Old receptacle in a metal 'handy box'.
Of course, I had to go find one of the new slim line types to even fit in the box. (I HATE it when people use handy boxes for receptacles!!)
So, I get done and my friend walks over to it with a plug in tester. I told him that his tester wouldn't work and that only the test button would as there was no ground wire.
Wrong!!!!
Not only did his tester show that there was a ground, but when he pushed the button on his tester, the GFCI tripped!
The only thing I can think of that provided a path to ground was the fact that the box was in a real rock plaster wall that went all the way to the floor. I could see the old NM in the box and it definitely was only two wire.
I just can't imagine that the plaster would be of low enough impedance to trick a tester into acting like there was a hard wired ground at the receptacle.
I just thought I would pass this along. Do not trust these testers 100 percent. (I don't trust ANY tester 100 percent, but that is just me!)
Mission:
Wrong!!!!
