spsmeltzer
- Dallas/Fort Worth Texas
I am working on a fairly old house that the customer wants to sell. In the kitchen and bathrooms the GFCI?s have no equipment ground. Attempting to test the GFCIs with a GFCI tester such the A. W. Sperry GFI -302A shows all them bad. Testing them with the push-to-test button shows them to be good. In the 2008 NEC ( and Previous, I believe ) 403.D(3)(b) and (c) indicates that I need to put a label on them that says ?NO EQUIPMENT GROUND?
Checking this tester indicates that the actuation of the test button puts a 15.55 K OHM resistance between the hot and ground pins. Having no ground is quite problematic when the test is predicated on hot-to-ground current flow.
1. Can I assume that since the test button on the GFCI indicates a good condition that they are safe, or am I putting myself into a potentially major liability situation by that assumption?
2. Is there a better type of tester available that will test a GFCI with ?NO EQUIPMENT GROUND??
3. Is this even compliant with 403.D(3) since it is required GFCI and not just replacing a 2 pin receptacle with a 3 pin GFCI protected recepticle?
Many Thanks
Stephen P. Smeltzer, Texas Journeyman Electrician
Many Thanks
