I got a call from a customer regarding a gfci that is tripping.
I’m confident that the receptacle is good because I recently installed it and it tested and worked fine at that time.
Normally I blame a tripped gfci to what is plugged into the gfci. That might also be the case here, but additionally I know that the load they’re feeding is quite a distance from the gfci receptacle.
I’ve read here about the effects of distance a load is from a gfci and possible problems with that.
I don’t remember the specific cause and couldn’t find a thread with the search function that describes it.
Does it have something to do with inductive coupling or something similar to that?
How far can a load realistically be from the gfci? I’m sure it’s based on VD and wire size, etc.
Thanks
Thanks
