coreyeskew
- Florida
- Electrician
Is anyone having problems with gfci breaker for the range tripping? I have wired several new homes and they work for awhile and then start tripping randomly. Really becoming annoying.
There are cases of the moisture in the calrod heating elements not being completely dried out in the manufacturing process, and this results in leakage current that is detected by the GFCI. If this is the case, you can use a standard breaker and run all of the elements on high for 30-45 minutes to complete the drying process and then install the GFCI breaker. This issue normally occurs when you first turn on the stove. It it is happening after the stove has been in use for awhile, it is probably something else.I wouldn't think that moisture would be the issue since it is inside in a conditioned space.
