Something to think about?
Issue with polarity, Hot? Neutral? I have had GFCI trips from ?Series GFCI?S?
To even suggest bypassing a Safety when problem is known, in a public place no less.
Commmeted ? Next step is to install a disconnect and hard wire the icemaker to non GFCI ckt. I'm a big believer in the life saving attributes of GFCI's. I would remove the GFCI protection only as a last resort.?
422.51 Cord-and-Plug-Connected Vending Machines.
Cord-and-plug-connected vending machines manufactured or re-manufactured on or after January 1, 2005, shall include a ground-fault circuit interrupter as an integral part of the attachment plug or be located within 300 mm (12 in.) of the attachment plug. Older vending machines manufactured or remanufactured prior to January 1, 2005, shall be connected to a GFCI-protected outlet. For the purpose of this section, the term vending machine means any self-service device that dispenses products or merchandise without the necessity of replenishing the device between each vending operation and is designed to require insertion of a coin, paper currency, token, card, key, or receipt of payment by other means.
FPN: For further information, see ANSI/UL 541-2005, Standard for Refrigerated Vending Machines, or ANSI/UL 751-2005, Standard for Vending Machines.
