I have a communications van that carries a lot of computer/televsion equipment. We use the van at football games and other equipment that are used at the stadium were causing voltage sags and causing problems to the equipment in the van. We installed a voltage regulator on the van and that stopped the noise in the system. The problem now is that we have since added GDCI breaker to the system and now when we turn enough equipment on it trips. I put a power quality meter on it and there is current going to ground for a splent second when turning on equipment (done without the GFCI). The question I have is could it be that voltage regulator causing current to goto ground? Anyone have any ideas? PS there are a lot of harmonics on the truck because of the computer, maybe another problem?
