A concrete contractor uses Hilti core drills served by portable generators for remote locations having no 120VAC. The core drills have GFCI protection in the cords. The drills will work every day until they don't. Test the drill on utility power and the drills work fine. Each time this has happened, a new generator was purchased to run the core drills, and then everything works.
What is happening to these 3KW generators that will not let the GFCI reset? The gensets are locally purchased at a big box store.
I expect load to trip GFCIs, not the source power.
