Hi, Went to troubleshoot GFCI breakers tripping for no aparent reason. Heres the setup 3 20A circuits in a single EMT conduit all circuits GFCI protected by there own GFCI breaker. Saw with my own eyes that all 3 breakers tripped at the same time! I have checked all connections at the receptacles. The equipment ground is insulated so no bare copper to neutral problem. After checking all connection I put evey thing back together and 3 hrs later they tripped again. I now have made sure there is nothing plugged in to these receptacles. I will check tomorrow to see if something plugged in was the problem. Does anyone have any idea what the problem could be?
