Hello, working inside of a double wide mobile home wherein there is 3 GFCI outlets all on the same circuit. One in each bathroom, and one mounted on the outside of the home. One bathroom had GFCI outlet go bad (approximately 17 years old) and opened the circuit to the 2nd bathroom and the single outlet outside. The broken GFCI was wired as the first outlet in the circuit properly protecting all other outlets.....and the lights, light switches, and exhaust fan in the 2nd bathroom.
So power going into the first GFCI outlet was on the "line" side, and wire leaving was on the "load" side. The two other GFCI outlets were both wired with the line going in and the line going out both mounted to the "line" side of the outlet....why would someone of done that, and what is the result of such a double "line" wiring situation ?Should I re-wire them with the wires leaving the outlet onto the "load" side. Since the first outlet is in effect protecting everything downstream, should I replace the two other GFCIs....one near a bathroom sink and the other mounted outdoors.....with regular outlets ?
I think I read somewhere wherein more than one GFCI wired into a circuit would limit the voltage at the end of the circuit. I was wondering if that is why they might of wired the GFCIs incorrectly.....
Mike
Mike
