HELP. looking for a post that states you con not use a 3 prong plug on a gfci (2 wire ) with no egc.
1. Yes it can.A 120 v cord with a egc can not be used on a gfci with 2 wires. I can not find it in the nec.
That NEC list of things that can't be plugged in is dumb, in my opinion. It's absolutely unenforceable and certainly not going to be followed by the homeowner.
Just note carefully that the end result is not quite what you asked for.THANKS DAVE. I knew it was in the nec. I could not find it.
It is not prohibited to plug a three prong plug into a 2-wire GFCI receptacle, just to plug certain things that use three prong plugs into that receptacle.
Name some things with three prongs you can plug into a 2 wire gfci.
Says the man with a plug in portable headlight.
Just out of curiosity .what could operate with a three prong cord on a two wire gfci . ( other than a extension cord .lame answer )
A-3-prong plug with the ground-blade removed! A very commonly used "fix"!
Phil Corso
