Hi I have a question that I have been getting conflicting information on.
if a pump for a water feature (waterfall) at a swimming pool is on a contactor that is controlled by a switch outdoors to turn the contractor on and off. does the switch itself need to be gfci protected. Because it is a 120 volt switch controlling the contactor with no neutral ran to it, just power and switchleg. but the power to the pump itself is obviously controlled by a 240 volt gfci breaker that runs through the contactor.
