codeunderstanding
I went to do some service work on a old house and was working in the bathroom with the gfi. When I plugged my tester in to see if it worked the polarities were ok. I hit the test button and it didnt trip. When i hit the test button it said the hot and neutral were reversed. When you push the test button on the gfi it will trip. The line and loads are hooked up properly as there is only one wire in the box. I'm trying to figure out what could be wrong with it. Part of the house was rewired and some has some knob and tube in it that might be part of the problem.
