U2cy2
- Charlottesville Va
I have installed two double pole double throw switches on two 20 A GFCI circuit breakers for Holiday Lighting. One circuit, when I throw the switch from GFCI breaker to regular electrical breaker trips out, the other one does not. Both switches are wired the same way, switching the hot and neutral from totally separate circuits. I can't seem to find what may be wrong, why does one switch cause the breaker to trip and the other not to; or could it be the CFCI breaker?
