Is this residential or commercial, also what code cycle are you under?
Absolutely!... I strongly suggest that if the receptacle is 25' in the air that either a GFCI breaker is used or another GFCI device is installed in an easy to reach location to protect this circuit and use a standard receptacle up high at the camera.
