GFDI Faults of SMA Inverter 10000TL-20
Naeemuddin Amin
New User
Karachi, Pakistan
Retired GM from power inductry
I have residential two strings 12kw solar system consisting of 30 Trina 400w panels and SMA 10000TL-20 on-grid inverter, I am facing a problem of insulation resistance with 3501 code, me and my installer did our best to find the ground fault in PV arrays, panels, cables earthing, grounding, nuetral etc. but nothing found abnormal. I have a doubt about the mall function of GDFI relay inside the inverter, can anyone have experience to check GDFI and reset it, Thanks.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
