mossyhorns012
I currently came across a industrial shop that before they send out they're motors, they test the motors on a "test rig" which has a variac transformer which enables the to control the power from 3 phase 200 volts all the way up to around 600 volts. This company is affilaited with another company across seas that had a bad electrical accident with the use of one of the "test rigs" and do to this the company is determined to get gfi protection on all of the "test rigs". My question is this, to put a gfi in before the variac would negate the protection at the motor where it is needed so the next thought would be to put the gfi in after the variac, but I have not came across a gfi that will operate with that much of a voltage difference??
