hockeyoligist2
- close to greenville sc
This morning I ran into something strange and dangerous. I had a call about a GFI breaker tripping and shutting down an outside, plug connected piece of equipment. I checked the receptical to ground and had 120 v but to common had nothing. I pulled the box cover and there was no hot going to the gfi. checked the common and it had 45v to ground. The wires were numbered so i found a corresponding number on another (non gfi) breaker where someone had switched the wires, (had to have been done years ago) turned it off and the 45v went away as did the 120 at the receptical. I moved it to the gfi and it quit tripping, amps check ok etc. Shouldn't the gfi have tripped when they made the swap?
