Gfi Breakers
sd4524
I would like to install 2 pole gfi breakers for indoor shower (waterfall pump, heat )circuits. The circuits are 20a 208v. The motors do not have a neutral connection. Will the breakers trip without any neutral. I don't think there should be any problems but just want to be sure.
I have hooked up 2-pole jetted/heated tubs that do not use a neutral to 2-pole GFCI breakers. Per installation instructions.
Many hot tubs and spa units use to come with no required neutral and a GFCI was installed. It will function properly.
