Re: GFI Circuit
Point taken on the GFCI issue. No argument there.
I should have pinpointed that my reply was in response to this:
Hurk is wrong. Plugging your computer and monitor into different circuits will not effect how they work, as long as both circuits are properly wired.
In fact, you can plug each component of your computer system (monitor, case, speakers, printer, scanner, etc) into a different circuit and they will still work properly.
This statement does not correlate with my experience. This statement strays way beyond GFCI. I'm an old computer guy. New computer guys know the rules. Old computer guys know the exceptions. It can be helpful to know the exceptions. The same rule can be applied to the members of this forum: The young people know the rules; the old people know the exceptions
Plugging electronic items in to different circuits should have no effect on GFI's tripping. If a GFCI trips it's an indication of a deeper issue with the item or with the circuit. You've all covered that quite nicely-- but I could not ignore the above quote as it's a common misconception that computers are flexible about how you plug them in and the quality of their power source.
I call it the Poltergeist syndrome. There is something in your electrical system that is invisible but makes your computer unpredictable. Let's just call it dirty power. That's an oversimplification, but it's good enough for illustrative purposes. Computers thrive on clean power (another oversimplification-- but it'll do for now). Plugging your various computer items in to different circuits will almost guarantee to raise the head of Poltergeist. I am still learning more and more about this issue, but I know what I've witnessed.
I have seen complete computer networks that were suffering from Poltergeist. A recording VOM was placed on the circuit. The spikes and sags were all over the place during a 24-hour period. All the computers were crazy. Spikes & sags are a small component of what bothers computers-- but it was a start. As a test a mid-grade line conditioner was put on the worst offender. The computer got well. The LC was removed and the computer got sick. Computer devices (printers, monitors, etc.) were plugged in to bypass the LC and the computer got sick again. The fix was to plug the computer and all it's own peripherals into one LC. Cabling between peripherals will pass chassis ground noise and may become the path of least resistance if there is a fault.
Here's the kicker: When the worst computer and it's peripherals was plugged into the LC, all the other computer systems (not plugged into the LC) got well enough to not exhibit Poltergeist behavior! When the worst computer was taken off the LC, all the others got sick again too. Not saying the one LC fixed all the problems-- nor was that expected-- or the intention-- but it did. Sadly, the owner decided that the one test LC was enough of a fix and decided not to LC all the computer systems.
Sorry to go long. Sorry to stray off topic, but my short answer didn't cut it.
