jeff48356
- Livonia, Michigan
I just failed a final inspection for a new house only because the outlet for the sump pump in the basement wasn't a GFI. I had a single TR outlet on a dedicated 15A circuit for it, which is all that was required the last time I installed one. But this makes no sense. A sump pump is the last thing you would want on a GFI. What if it nuisance-trips unknowingly? Then you get water in your basement. Is there a new NEC code that requires GFI protection for this?
