I am a chemist who is reviewing a manual and soon to be installing a new piece of instrumentation. The instrument in question has a contained loop of water, pressurized air and of course is run by electricity. The question has arisen, is there a need for GFI, GFCI or nothing? Where do I find this out?
Details of the instrument:
110-260VAC
50-60 Hz
Max 2000W
Voltage will be transformed to 220 using internal transformer.
A surge protector protects the system against peaks in voltage.
The water in side the system is not completely closed as it is the humidity supply to a relative humidity control unit for a carefully controlled gas source.
Is this the proper place to ask this sort of question? I am in charge of maintaining the integrity of the manual while changing the English from a second language to a first...correct all the nuances of the language. In turn, a question was raised about the need for
GFI or GFCI.
Thank you.
110-260VAC
50-60 Hz
Max 2000W
GFI or GFCI.
Thank you.
