680.44 Protection. Except as otherwise provided in this
section, the outlet(s) that supplies a self-contained spa or hot
tub, a packaged spa or hot tub equipment assembly, or a fieldassembled
spa or hot tub shall be protected by a ground-fault
circuit interrupter.
(A) Listed Units. If so marked, a listed, labeled, and identified
self-contained unit or a listed, labeled, and identified packaged
equipment assembly that includes integral ground-fault circuitinterrupter
protection for all electrical parts within the unit or
assembly (pumps, air blowers, heaters, lights, controls, sanitizer
generators, wiring, and so forth) shall be permitted without
additional GFCI protection.
(B) Other Units. A field-assembled spa or hot tub rated 3
phase or rated over 250 volts or with a heater load of more
than 50 amperes shall not require the supply to be protected by
a ground-fault circuit interrupter.
