mudcat555
- Retired Electrician IBEW Local 38
This is the first time I've come across this situation. The customer is putting two bedrooms down in the basement. The code says all basement outlets are to be GFI protected, but it also says that all power in the bedroom has to be on an AFC. Do I put the bedroom circuits on arc fault breakers, and then use a GFI in each bedroom for one receptacle and piggy-back the remaining receptacles on the load side of the GFI? Given the over-sensivity associated with some arc-fault breakers, will a GFI on that circuit cause any nuisance tripping? What have others done in this situation?
