Gfi problem
jclayton
New member
When I tested my GFI outlet. It checked out to be Ground / Hot Reversed. I checked the GFI outlet and it was not reversed. What else would make the GFI outlet test out this way. Please advise..
al hildenbrand
Minnesota
Electrical Contractor, Electrical Consultant, Electrical Engineer
Re: Gfi problem
Welcome to the forum.
Sounds like a wiring problem. Better get the electrician to look at it.
What did you use to test with that gave you the polarity information?
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
Re: Gfi problem
Originally posted by jclayton:It checked out to be Ground / Hot Reversed.
I think you are using the wrong words to describe what the tested told you. If there were power on the ground wire, then you would get a shock every time you touched a metal thing that has wires going to it.
The Forum rules prohibit us from giving assistance to a person who is not an electrician, and who plans to do their own electrical troubleshooting and repair work.
I am closing this thread.
