flashlight
- NY, NY
- Electrician, semi-retired
Did service call today, new hair salon.
Two adjacent chairs are served by 3 110V receptacles on different phases of a 4-wire mwbc protected w/ 3 20A cb's (05 code) When they use one of their electric clippers it trips the GFI which is part of the male end of the blow dryer. It does this with different blow dryers and clippers. They are not plugged in on the same phase of the circuit.
The clippers are all rather old, metal frame w/ 2-wire power supply, no ground. They don't draw more than 2 amps. There
are 3 of them plugged into a power strip, but it seems they all can cause the tripping.
Could this be some kind of induction in the neutral that is fooling the GFI into seeing an imbalance ? Typically, the blow dryers are not even on when this happens so there is no current passing through the cords.
I am thinking I am going to have to get them a separate 2-wire circuit for
the clippers.
Would greatly appreciate any insight on this.
the clippers.
