GFI protection for multi motor refrigeration unit that requires a water supply
Zaffel3000
Fort Wayne, IN
I have a frozen yogurt machine that is powered by 208-230 V and 3 phase power at 60 HZ. This product has a compressor for refrigerant and also requires a water supply.
My question involves GFI protection. The installation manual does not call for a GFI but the drawings provided by the building owner where the product was installed has GFI protection.
I am concerned that this equipment should have GFI protection, since it has a water source within the product that could potentially cause a ground fault if it leaks.
Does anyone have any references that I can refer to or relevant experience on products like this in commercial kitchens?
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
What is your involvement in this project? Is this a new installation, and if so are you its designer? Or are you investigating a previous failure or accident involving this equipment?
Zaffel3000
Fort Wayne, IN
The equipment had an unrelated failure that has brought me in. The equipment had been operating for some time without issue but I am reviewing the installation and protection.
