I did a hospital job a few years back where we had all corridor receptacles as GFI protected. I can't for the life of me remember where this requirement was given (code reference). Any idea?
Thanks,
Keri :grin::grin:
The only things I could think of would be "wet location" as Roger mentioned, or for vending machines.
Definitely not vending related. All of the corridor receptacles were GFI.
Are you sure it was GFI, and not tamper proof, or maybe emergency??
Sometimes engineers can design above and beyond code minimums without citing a reason why.
Are you ready for more snow?
Oh yeah, it's snowing right now.I wouldn't care except we have to have 4 large feeders pulled and terminated by Monday morning, but we have the weekend if tomorrow is snowed out.
How about yourself?
Roger
Because in the opinion of the engineer it is the right thing to do. And thats what the customer is employing an engineer for - to get the right design.Why would they do this [design above and beyond code minimums] besides driving the overall cost to the owner up?
Why is that his opinion? Is it because the designer doesn't know they aren't necessary so he is going with the CYA design in these corridors?Because in the opinion of the engineer it is the right thing to do.
And the right design is not necessarily over design.And thats what the customer is employing an engineer for - to get the right design
So, in your opinion the "minimum" means borderline dangerous? The NEC is already well over minimum safety so when the term "minimum requirement" is used in describing it, it does not mean it is a cheap, dangerous, or irresponsible installation when it is followed to a teePut it another way - I keep hearing people chant "the NEC isn't a design manual" - thus you cant rely on the NEC for design, and thus minimum compliantly design should - most of the time - be inadequate.
So if someone wanted to buy a Crown Vic you would tell them they need a Lincoln simply because it cost more?The same thing using a little math - given the NEC provides "minimums", then the "average" design should always be in excess of the minimum.
