electrican
- Ohio
How many duplex recpt. can you have on the load side of a GFI Recpt.
Residential - unlimited unless limited by local amendments.Originally posted by electrican:
Is a general rule, to find the answer to your specific question you will need to look at the instructions that came with the GFCI outlet to see if there is any limit to downstream loads on that particular unit.110.3(B)Installation and Use. Listed or labeled equipment shall be installed and used in accordance with any instructions included in the listing or labeling.
