buckofdurham said:Every thing in the laundry room is required to be on a gfci. except the washer.
I'm not sure of the years the code changed. It has nothing to do with being within 6 ft of the wash tub.
Gfci is required even if their is no sink in the room.
In 08 the washer may also be required to be on gfci I'll have to check that.
tcwaters said:I am totally confused. Are GFI's required in laundry rooms or not? Can anyone cite the reference in the code explaining whether or or not receptacles in a laundry room should be on GFI and if the receptacle the washer is plugged in to should be on GFI?
No requirement.tcwaters said:I am totally confused. Are GFI's required in laundry rooms or not? Can anyone cite the reference in the code explaining whether or or not receptacles in a laundry room should be on GFI and if the receptacle the washer is plugged in to should be on GFI?
stickboy1375 said:No, unless of course the laundry room is in a bathroom, unfinished basement, garage, outbuilding, or outside... :grin:
C3PO said:I disagree with this. Receptacles in a laundry room only need to be GFCI protected is there is a sink in the laundry room , and then only the receptacles that are within 6 feet of the outside edge of the sink wether it servers the washer or not. 210.8(A)(7)
tcwaters said:Thank you for providing this information. I was able to find the section/requirement. :smile:
