E erdy7821 Member Jan 29, 2004 #1 If you have an undercabinet light above a sink and the the light is 18" above the sink, does it need to be gfi protected? I see where they raised the height of rec. from 18" to 20", but can't find anything on the lighting.
L luke warmwater Senior Member Jan 29, 2004 #2 Re: GFI Undercabinet Light Not for the light. Is there a receptacle installed as part of the fixture assembly?
electricmanscott Senior Member Location Boston, MA Occupation Massachusetts Master Electrician, one man show. Jan 29, 2004 #3 Re: GFI Undercabinet Light I see where they raised the height of rec. from 18" to 20" Click to expand... What are you getting at with this.
