Mark Urban
New member
- Great Bend Kansas
If using 12/3 home run to the panel as 2 circuits to a kitchen can you install a GFI receptacle on each hot from a single pole breaker and share the neutral if you make it up and split off to each GFI receptacle and feed load side to downstream receptacles? Is there another way to make the 12/3 home run work is this doesn't?
