Alan327
- St.Louis, MO
Running a residental 20A receptacle circuit (for outdoor Xmas lights) through a GFIC receptacle that is mounted to the bottom of the switch panel seems like it should be in violation of the NEC.
Is this because you cannot mix outside and inside receptacles on the same circuit or you cannot attach a GFIC recepatcle to the panel and then run the circuit from the breaker through the GFI receptacle then back into the panel?
I am looking for some support that this not only falls short of a "best practice" but is actually illegal.
