gfis and landscape transformers
djd
Has anyone ever had a problem with gfis feeding landscape transformers , we are using a volt transformer for a led lights. I could not see see any readily problem , even turned off the load and it still happened and everything is dry.
So, your GFCI is tripping with landscape lighting?
Did you test without transformer plugged in?
Then, test with transformer plugged in and LV wires disconnected?
