mtfallsmikey
I have several GFI receptacles mounted in recessed boxes on the outside walls of my house, covers are old-style hinged, with a gasket on the lid. All receptacles are not wet location rated. I lifted the lid on one the other day to plug in a pressure washer, noticed some droplets of condensation on the face of the GFI. That receptacle worked, but there have been a couple of them that went bad, had voltage to them, was not able to reset. Is it possible that warmth coming thru the wall causing the moisture/condensation on or inside the receptacle would cause it to go bad? Do I need to convert to all wet-location rated? I probably should be changing all of these covers out to the in-use type... Thoughts?
